Display Port VLAN Information
Switch:1>enable
Switch:1#show interfaces gigabitethernet vlan
Port Vlans
PORT DISCARD DISCARD DEFAULT VLAN PORT UNTAG DYNAMIC UNTAG FA/
NUM TAGGING TAGFRAM UNTAGFRAM VLANID IDS TYPE DEFVLAN VLANS VLANS Flex UNI
1/1 disable false false 1 1 normal disable P 1 disable
1/2 enable false false 1 1,3,10 normal disable P 1,10 disable
1/3 enable false false 1 1,10,20 normal disable P disable
DYNAMIC VLAN Legend:
P=Protocol enabled.
The following table defines parameters for the show interfaces command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
